CristiS
Mar 12, 2022Aspirant
Bad Request 400 from router Genie software on WNDR4300
I have been using the online interface at http://192.168.1.1/adv_index.htm for years without problems. Now, every time I try to alter my MAC address filtering I get that 400 when I click to apply ad...
michaelkenward
Mar 12, 2022Guru - Experienced User
What's the firmware on the WNDR4300?
That interface looks odd. "Netgear Genie"? I don't see that.
Everything else in that interface works just fine, and I am fairly certain the issue started after the last firmware upgrade.
So roll back to the previous firmware to confirm if this really is a firmware thing.
I wouldn't hold out much hope of getting Netgear to fix anything on the WNDR4300. It is a basic router that dates back to 2015, with technology from that era. There hasn't been a firmware update in four years.
CristiS
Mar 14, 2022Aspirant
Yes, it is an older model, but if it meets my needs I see no reason to shell another one, two or three hundred bucks for a new one. I don't have any wifi6 devices yet, and the coverage is good, so I am good with the modem, I'm just pissed off that Netgear BROKE the interface with their firmware update. Sounds like I am out of luck. The router has the latest firmware(1.0.2.104), and I don't have the older version file. Within the app (or web interface) there is no option to roll back a firmware update. Luckily I was able to remove the MAC filtering through the desktop app, so now I can use it without that feature. It's not like it adds much security anyway.
Thank you for your answer.
