Inder_2001
Jan 01, 2023Aspirant
Bandwidth Control in R6220 AC-1200
Is it possible to control bandwidth on my Netgear R6220 AC-1200 router, if yes. How do I do it
michaelkenward
Jan 01, 2023Guru - Experienced User
What are you trying to achieve by "Bandwidth Control"?
Start with the problem in hand rather than an idea of how you might fix it.
The R6220, from 2015, is one of Netgear's lesser routers and may lack the controllability of flashier modems.
To see what you can do with the router, manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
- Inder_2001Jan 07, 2023AspirantSo, i wanted to limit the internet speed for some devices that are connected to my router
- michaelkenwardJan 07, 2023Guru - Experienced User
Inder_2001 wrote:
So, i wanted to limit the internet speed for some devices that are connected to my routerI think we already knew that.
Could you answer the questions in my previous message?
What they boil down to is why do you want to limit the internet speed for some devices connected to your router?
Knowing that might help people to offer thoughts beyond simply looking up QoS in the manual for your R6220.
- Inder_2001Jan 24, 2023AspirantThere are some devices, that are using my internet for free. I just don't wanna block them. I wanna limit there internet speed to the that they don't wanna use it willingly
