Lamer
Oct 14, 2015Aspirant
Bandwidth Sharing
Greetings, is there a router that can share bandwidth automatically? We have a small business with about 10-20 connections using an ADSL2+ connection. When someone uses dropbox, everyone else...
- Oct 20, 2015
QoS feature should be able to help you prioritize the network traffic.
Perhaps, you can set computers that uses dropbox to be on low priority.
Check this link on how QoS can be configured on our routers.
If this isn't suitable, perhaps you may need something like, Load Balancing feature, which is available in our Business Routers.
netwrks
Oct 14, 2015Master
There are various Nighthawk Series routers, that support QoS, which may resolve your issue.
- LamerOct 18, 2015Aspirant
From what I can tell, these routers are only good for streaming / gaming. I don't think they'll help much if a few people are using dropbox while other devices are browsing the web?
- ElaineMOct 20, 2015NETGEAR Employee Retired
