niner3014
Sep 07, 2021Aspirant
Battery Back-Up N600
 Hi, I am 'new' to this community/forum.  Due to power outages I am looking for a Back-Up Battery to power my Netgear N600 Router.  { cable box already has is own back-up battery]. Any suggestions are...
- Sep 10, 2021Hi Thanks to everyone. Figured that I would have to get one that is 480W to have a reasonable back-up time; found out that the N600 WNDR3400v3 draws 14.5w. Was looking and decided to go with this:
Sep 07, 2021Guru - Experienced User
I'd buy a cheap UPS. Battery backup system.
that way you can plug multiple systems into it like the modem and router.
They can be found all over amazon or other 3rd parties.
