niner3014
Sep 06, 2021Aspirant
Battery Back-Up N600
Hi, I am 'new' to this community/forum. Due to power outages I am looking for a Back-Up Battery to power my Netgear N600 Router. { cable box already has is own back-up battery]. Any suggestions are...
- Sep 10, 2021
Hi Thanks to everyone.
Figured that I would have to get one that is 480W to have a reasonable back-up time;
found out that the N600 WNDR3400v3 draws 14.5w.
Was looking and decided to go with this:
Sep 08, 2021Guru - Experienced User
Poor math on my part.
18 watt power supply x8 hours is 144 watt. for your device.
I was roughly figuring it at 20watt x 8 hours =160.
for a higher performing its the upto 480watt. (60 watt x 8 hours)
Keep in mind that most power supplies are over rated.
a lot of the power supply have where you can plug in what you need (in terms of power) and will tell you how long it'll run.
niner3014
Sep 10, 2021Aspirant
- plemansSep 10, 2021Guru - Experienced User
should work well! (can't see your specific one but 480w should give you plenty of time)
- michaelkenwardSep 10, 2021Guru - Experienced User
