niner3014
Sep 07, 2021Aspirant
Battery Back-Up N600
Hi, I am 'new' to this community/forum. Due to power outages I am looking for a Back-Up Battery to power my Netgear N600 Router. { cable box already has is own back-up battery]. Any suggestions are...
- Sep 10, 2021
Hi Thanks to everyone.
Figured that I would have to get one that is 480W to have a reasonable back-up time;
found out that the N600 WNDR3400v3 draws 14.5w.
Was looking and decided to go with this:
niner3014
Sep 10, 2021Aspirant
Sep 10, 2021Guru - Experienced User
should work well! (can't see your specific one but 480w should give you plenty of time)
- michaelkenwardSep 10, 2021Guru - Experienced User
