xytsrm
Dec 07, 2021Tutor
Beacon-Rate
What is the default beacon-rate of the subject router, and can it be changed?
- Dec 09, 2021
Thanks for the information. While it does show a typical beacon interval for that router, it might still be applicable to my router.
Thanks again for your time, I'm going to try and contact Network technical support.
xytsrm
Dec 08, 2021Tutor
I've previously checked in the setting you suggest, I don't see any reference to beacon or DTIM. Attached are the 2.4GHz setting (5Ghz not enabled).
Dec 08, 2021Guru - Experienced User
I presume one reason those are not seen maybe that those are automatically handled now days as those are seen much anymore in router UIs. Older routers had those features. Also maybe that due to wifi chipset used, something that isn't needed or used. CTS can be changed however default is recommended. Ive seen 64 used in newer generation routers as default, however seems to cause problems for some. 2347 seems to be the norm and works best.
- xytsrmDec 08, 2021Tutor
The question remains; if the beacon rate is not adjustable, what is it set at?
- FURRYe38Dec 08, 2021Guru - Experienced User
Not sure if this applies to NG routers:
https://askinglot.com/what-is-beacon-in-wireless-network
Since its not seen in the UI, hard to tell what NG is using.
