xytsrm
Dec 07, 2021Tutor
Beacon-Rate
What is the default beacon-rate of the subject router, and can it be changed?
- Dec 09, 2021
Thanks for the information. While it does show a typical beacon interval for that router, it might still be applicable to my router.
Thanks again for your time, I'm going to try and contact Network technical support.
xytsrm
Dec 08, 2021Tutor
The question remains; if the beacon rate is not adjustable, what is it set at?
Dec 08, 2021Guru - Experienced User
Not sure if this applies to NG routers:
https://askinglot.com/what-is-beacon-in-wireless-network
Since its not seen in the UI, hard to tell what NG is using.
