xytsrm
Dec 07, 2021Tutor
Beacon-Rate
What is the default beacon-rate of the subject router, and can it be changed?
- Dec 09, 2021
Thanks for the information. While it does show a typical beacon interval for that router, it might still be applicable to my router.
Thanks again for your time, I'm going to try and contact Network technical support.
xytsrm
Dec 08, 2021Tutor
All routers, whether user adjustable or not, transmitt a beacon containing the router SSID and additional information at regular intervals they can vary from router to router, but are usually in the 100-200ms range. It's necessary for specific clients, that need to sleep between beacons to conserve power, to know when to wake-up to maintain connection.
Dec 09, 2021Guru - Experienced User
I found this, though a different router model, it shows what NG uses for what your looking for:
- xytsrmDec 09, 2021Tutor
