xytsrm
Dec 07, 2021Tutor
Beacon-Rate
What is the default beacon-rate of the subject router, and can it be changed?
- Dec 09, 2021
Thanks for the information. While it does show a typical beacon interval for that router, it might still be applicable to my router.
Thanks again for your time, I'm going to try and contact Network technical support.
Dec 09, 2021Guru - Experienced User
I found this, though a different router model, it shows what NG uses for what your looking for:
xytsrm
Dec 09, 2021Tutor
