krazybob
Apr 19, 2017Aspirant
Best Model to Buy 100Mbps
I currently have a RangeMax N150 WPN824N that is supposed to give me up to 150Mbps. On a wired connection nit does. But not wireless where I average 68Mbps. But it varies. I have a Samsing LED TV wit...
- May 24, 2017
Hi krazybob
No point to be made.U R Most Welcome.
Just trying to pool knowledge to assist in getting the best out of your networking situation.
I think I see your point. Let's see if I've got this right and add more knowledge to your years of knowledge!Quote " I will only repeat the the theorhetical maximun speed of 802.11 n is 600Mbps"
The 802.11n is a specification/standard with different manufactures and models meeting the N spec range i.e. (54 - 600Mbps)."802.11n operates on both the 2.4 GHz and the 5 GHz bands. Support for 5 GHz bands is optional. It operates at a maximum net data rate from 54 Mbit/s to 600 Mbit/s. The IEEE has approved the amendment, and it was published in October 2009".
The N model of the router is and indicator to be devided by 2 (1 for each band, 2.4Hz and 5GHz respectively) to give you the rate at which data will move across
wifi to (speed capable) devices/clients you connect to your network.
I have Netgear WNDR4500v2 it is a N900 class router. (The D in the model number means this router will operate both bands at the same time).
900 devided by 2 = 450 which means I will get in theory up to 450 Mbps Data Transfer Rate across both bands.
Your's is the RangeMax N150
So your Data rate in theory will max would be 150 divided by 2 = 75Mbps Data Transfer Rate
This explains your "no more than 65Mbps on a good day".
Even with a Wifi card that can handle 300Mbps.
The R7000 in theory will give you 700Mbps
Runing around 600+13000Mbps
The Orbi is 3Gbps Clearly way more speed.
How well these two models perform I can't say as I have no experience with them... but one day... perhaps:smileyvery-happy:
Hope this helps
RSlack
krazybob
Thank you for the reply and your honesty.
So even if I upgrade I won't see a speed improvement on wireless. Why upgrade then? I already have an 802.11N. I have it set for 150Mbps and I dont get half of that.
mondenath
Apr 19, 2017Prodigy
No you cant complain the router if the client cant take advantage of the router speed. More over the advertized speed of 1770 is mere gimmick. even if you have two router bridged practically you cant achieve in that close speed. But yes you are good to go with R7800 unless you are stick to budget get R7000.
So if your concern is wireless speed. its definitely not the range but the Wireless N has a cap of 150-300Mbps. Most portable devices only have 1x1 antenna for transfer. Current TV and smart devices including phones started to come with 2x2 antenna when connected in N you might get 150Mbps or if AC band 866Mbps.
So you will see the improvement if you have AC band clients like say your TV in this scenario. But mobile clients will also see some improved response
- krazybobApr 20, 2017Aspirant
I don't recall "complaining."
- slackrlMay 22, 2017Luminary
Hi krazybob:
In reading this post... Maybe a interjection here would help.
On wireless you can only go as fast as the wireless device is capable of receivng. In your equipment case.
-Charter/Spectrum 100/20 internet (which is good! I have Charter and get 60/5)
-RangeMax 150
( I think the RangeMax puts out 13 - 20Mbps Wireless) I could be wrong on that.
So let's just say RangeMax could put out 150 Mbps over wireless.
Now the speed you get will also depends on the speed at which the device can receive.
In this Example:
1. Cell Phone rated at 54Mbps - Cell phone will report 54Mbps becasue it is all the Cell Phone can receive.
2. Streaming device rated at 85Mbs - Streaming device will report 85Mbps because it is all the Streaming device can receive.
3. AppleTV 4th Gen rated at 300Mbps (Wireless 5G)
AppleTV 4th Gen with RangeMax - AppTv 4th Gen will report 150Mbps because it is all the RangeMax can deliver (per this example),
although AppleTv can receive 300Mbps, if the router will put that amount of wireless speed.
(Say an N900 router will put out 450Mbps over Wireless) then The AppleTv will report 300Mbps.
Also keep in mind as stated earlier in this discussion, the distance/location and barriers between the device and router can affect signal and speed.
Hope this helps
RSlack
- krazybobMay 22, 2017Aspirant
Thank you for a very informative reply. I had not considered the wireless adapter speed. I just looked it up and see that I have:
Dell Wireless 1397 802.11g Mini-Card
Dell Wireless 1520 Wireless-N Mini-CardI don't know how to select the type N or if it automatic. It looks like it is automatic because I just checked my wireless connection and it shows that I am using the 1520-N. A 802.11n has a theorhetical speed of 600Mbps but I know that isn't in the real world. I get no more than 65Mbps and that's on a good day. If I close the door between my office and bedroom I may drop to just a couple of bars on the laptop. I know that I can run a wired connection but that is not convenient. I can connect to neighbors wireless through walls and disstance and get a good connection so it isn't necessarily the laptop.
I also
