krazybob
Apr 20, 2017Aspirant
Best Model to Buy 100Mbps
I currently have a RangeMax N150 WPN824N that is supposed to give me up to 150Mbps. On a wired connection nit does. But not wireless where I average 68Mbps. But it varies. I have a Samsing LED TV wit...
- May 24, 2017
Hi krazybob
No point to be made.U R Most Welcome.
Just trying to pool knowledge to assist in getting the best out of your networking situation.
I think I see your point. Let's see if I've got this right and add more knowledge to your years of knowledge!Quote " I will only repeat the the theorhetical maximun speed of 802.11 n is 600Mbps"
The 802.11n is a specification/standard with different manufactures and models meeting the N spec range i.e. (54 - 600Mbps)."802.11n operates on both the 2.4 GHz and the 5 GHz bands. Support for 5 GHz bands is optional. It operates at a maximum net data rate from 54 Mbit/s to 600 Mbit/s. The IEEE has approved the amendment, and it was published in October 2009".
The N model of the router is and indicator to be devided by 2 (1 for each band, 2.4Hz and 5GHz respectively) to give you the rate at which data will move across
wifi to (speed capable) devices/clients you connect to your network.
I have Netgear WNDR4500v2 it is a N900 class router. (The D in the model number means this router will operate both bands at the same time).
900 devided by 2 = 450 which means I will get in theory up to 450 Mbps Data Transfer Rate across both bands.
Your's is the RangeMax N150
So your Data rate in theory will max would be 150 divided by 2 = 75Mbps Data Transfer Rate
This explains your "no more than 65Mbps on a good day".
Even with a Wifi card that can handle 300Mbps.
The R7000 in theory will give you 700Mbps
Runing around 600+13000Mbps
The Orbi is 3Gbps Clearly way more speed.
How well these two models perform I can't say as I have no experience with them... but one day... perhaps:smileyvery-happy:
Hope this helps
RSlack
krazybob
Thank you for the reply.
I am not a gamer so a 7800 is way too fast for my needs. It looks like an AC1200 for even an AC1900 would serve me well. If I read the details right I can even run a NAS drive off of the USB port? The prices are so close that I might just go to the 7800.
But here's the issue. The built-in LAN ports will give me blazing speed but I need wireless speed. If I am paying for 100 down I want to see 100 down (minus overhead.) Or close to it. But this 20Mbps to cell phones and laptops 15 feet away doesn't do it for me. What if I want to run a small web server or mail server? A LAN port should be able to do it at 20Mbps.
michaelkenward
Apr 20, 2017Guru - Experienced User
krazybob wrote:But here's the issue. The built-in LAN ports will give me blazing speed but I need wireless speed. If I am paying for 100 down I want to see 100 down (minus overhead.)
I can't see any mention of this, and it may not be relevant to you, but the built-in LAN bit of your hardware is probably 100BASE-Tx, that is 100 Mbps, hardly "blazing speed".
Even wired network connections are running at the limits of your Internet connection. Modern kit has LAN at 1000 Mbps.
