krazybob
Apr 19, 2017Aspirant
Best Model to Buy 100Mbps
I currently have a RangeMax N150 WPN824N that is supposed to give me up to 150Mbps. On a wired connection nit does. But not wireless where I average 68Mbps. But it varies. I have a Samsing LED TV wit...
- May 24, 2017
Hi krazybob
No point to be made.U R Most Welcome.
Just trying to pool knowledge to assist in getting the best out of your networking situation.
I think I see your point. Let's see if I've got this right and add more knowledge to your years of knowledge!Quote " I will only repeat the the theorhetical maximun speed of 802.11 n is 600Mbps"
The 802.11n is a specification/standard with different manufactures and models meeting the N spec range i.e. (54 - 600Mbps)."802.11n operates on both the 2.4 GHz and the 5 GHz bands. Support for 5 GHz bands is optional. It operates at a maximum net data rate from 54 Mbit/s to 600 Mbit/s. The IEEE has approved the amendment, and it was published in October 2009".
The N model of the router is and indicator to be devided by 2 (1 for each band, 2.4Hz and 5GHz respectively) to give you the rate at which data will move across
wifi to (speed capable) devices/clients you connect to your network.
I have Netgear WNDR4500v2 it is a N900 class router. (The D in the model number means this router will operate both bands at the same time).
900 devided by 2 = 450 which means I will get in theory up to 450 Mbps Data Transfer Rate across both bands.
Your's is the RangeMax N150
So your Data rate in theory will max would be 150 divided by 2 = 75Mbps Data Transfer Rate
This explains your "no more than 65Mbps on a good day".
Even with a Wifi card that can handle 300Mbps.
The R7000 in theory will give you 700Mbps
Runing around 600+13000Mbps
The Orbi is 3Gbps Clearly way more speed.
How well these two models perform I can't say as I have no experience with them... but one day... perhaps:smileyvery-happy:
Hope this helps
RSlack
krazybob
Apr 20, 2017Aspirant
I don't recall "complaining."
slackrl
May 22, 2017Luminary
Hi krazybob:
In reading this post... Maybe a interjection here would help.
On wireless you can only go as fast as the wireless device is capable of receivng. In your equipment case.
-Charter/Spectrum 100/20 internet (which is good! I have Charter and get 60/5)
-RangeMax 150
( I think the RangeMax puts out 13 - 20Mbps Wireless) I could be wrong on that.
So let's just say RangeMax could put out 150 Mbps over wireless.
Now the speed you get will also depends on the speed at which the device can receive.
In this Example:
1. Cell Phone rated at 54Mbps - Cell phone will report 54Mbps becasue it is all the Cell Phone can receive.
2. Streaming device rated at 85Mbs - Streaming device will report 85Mbps because it is all the Streaming device can receive.
3. AppleTV 4th Gen rated at 300Mbps (Wireless 5G)
AppleTV 4th Gen with RangeMax - AppTv 4th Gen will report 150Mbps because it is all the RangeMax can deliver (per this example),
although AppleTv can receive 300Mbps, if the router will put that amount of wireless speed.
(Say an N900 router will put out 450Mbps over Wireless) then The AppleTv will report 300Mbps.
Also keep in mind as stated earlier in this discussion, the distance/location and barriers between the device and router can affect signal and speed.
Hope this helps
RSlack
- krazybobMay 22, 2017Aspirant
Thank you for a very informative reply. I had not considered the wireless adapter speed. I just looked it up and see that I have:
Dell Wireless 1397 802.11g Mini-Card
Dell Wireless 1520 Wireless-N Mini-CardI don't know how to select the type N or if it automatic. It looks like it is automatic because I just checked my wireless connection and it shows that I am using the 1520-N. A 802.11n has a theorhetical speed of 600Mbps but I know that isn't in the real world. I get no more than 65Mbps and that's on a good day. If I close the door between my office and bedroom I may drop to just a couple of bars on the laptop. I know that I can run a wired connection but that is not convenient. I can connect to neighbors wireless through walls and disstance and get a good connection so it isn't necessarily the laptop.
I also
- William10aMay 22, 2017Master
Any of the r7000 and above should do the job just keep mind what may be the next internet speed you may update too in future a 1gb port should be enough to hold you for the foreseeable future.
- krazybobMay 23, 2017Aspirant
Thank you but an R7000 is way overkill. I can handle 65Mbps to my laptop or cellp phone.
My issue is more the crappy performance of the Samnsung 50" LCD Smart TV that can't manage 1.5Mbps in the same room as the laptop getting 65Mbps. I like to watch Youtube video's and it buffers... "Loading...": and then times out. That's more an issue with Samsung but they won't admit it. It has been suggested that I buy an external Chromecast device. You should have heard the phone calls with Samsung and Google each blaming one another to the point of denying that the TV even has Chromecast. "It's a software isssue. Let me transfer you to Google..." "It's a hardware issue. Let me transfer yoou to Samsung..." I would run a hard line but I have no guarantee that will solve the problem. Is it that I am running DHCP? I have a spare static IP. Should I installk Orbit? That's just a bit more than an R7000 at $179.
- TheEtherMay 23, 2017Guru
Are you sure your Samsung has Chromecast built in? It's not listed as a supported brand by Google (link). What's the model of your TV?
DHCP should not be an issue, but you can always try a static IP to eliminate one more variable. A wired connection would also eliminate another variable. You can temporarily set up a wired connection for testing purposes. Otherwise, consider getting an external streamer (Chromecast, Amazon Fire TV, Roku, etc.). I have a older Samsung TV and it's simply terrible at streaming.
