krazybob
Apr 19, 2017Aspirant
Best Model to Buy 100Mbps
I currently have a RangeMax N150 WPN824N that is supposed to give me up to 150Mbps. On a wired connection nit does. But not wireless where I average 68Mbps. But it varies. I have a Samsing LED TV wit...
- May 24, 2017
Hi krazybob
No point to be made.U R Most Welcome.
Just trying to pool knowledge to assist in getting the best out of your networking situation.
I think I see your point. Let's see if I've got this right and add more knowledge to your years of knowledge!Quote " I will only repeat the the theorhetical maximun speed of 802.11 n is 600Mbps"
The 802.11n is a specification/standard with different manufactures and models meeting the N spec range i.e. (54 - 600Mbps)."802.11n operates on both the 2.4 GHz and the 5 GHz bands. Support for 5 GHz bands is optional. It operates at a maximum net data rate from 54 Mbit/s to 600 Mbit/s. The IEEE has approved the amendment, and it was published in October 2009".
The N model of the router is and indicator to be devided by 2 (1 for each band, 2.4Hz and 5GHz respectively) to give you the rate at which data will move across
wifi to (speed capable) devices/clients you connect to your network.
I have Netgear WNDR4500v2 it is a N900 class router. (The D in the model number means this router will operate both bands at the same time).
900 devided by 2 = 450 which means I will get in theory up to 450 Mbps Data Transfer Rate across both bands.
Your's is the RangeMax N150
So your Data rate in theory will max would be 150 divided by 2 = 75Mbps Data Transfer Rate
This explains your "no more than 65Mbps on a good day".
Even with a Wifi card that can handle 300Mbps.
The R7000 in theory will give you 700Mbps
Runing around 600+13000Mbps
The Orbi is 3Gbps Clearly way more speed.
How well these two models perform I can't say as I have no experience with them... but one day... perhaps:smileyvery-happy:
Hope this helps
RSlack
William10a
May 25, 2017Master
If that's what your chorma connection on your tv is I can see why it is a hard problem to solve you have at lease two points of possible problems and the performance hit when you use another device to relay a signal from point a to point c via point b. Point b has to receive and transmit the signal again in a way like a wifi extender were you can lose up to half the speed of the original wifi source. You could possible use a network attached Chorma player box hard wird via hdmi to the tv if you have a freehdmi port.
michaelkenward
May 28, 2017Guru - Experienced User
Powerline (look it up in the products pages) is a natural solution for smart TVs and similar devices.
- krazybobMay 28, 2017Aspirant
If you are referring to IP over AC power line I already have a Netgear. But as an extra class amateur radio operator I know that broadband signals tend to wipe out ham radio communications. I could try it but I won't be surprised if it causes interference.
I think I'm better off with an R7000 mounted above my desk instead of along side of it, or an Orbi that uses 5GHz for backhaul. All of my laptop's are on 2.4GHz as are my cellphones.
