JackNapier
Dec 28, 2023Follower
Best Router for Fidium fiber
i have 2gb fiber in the home from fidium. of course their equipment only allows 1gb. To get 2gb speed I was told I need to buy a new router. I called fidium and they recommended a modem that ended...
Dec 28, 2023Guru - Experienced User
If your ISP supports 2Gb services, then you'll need a router that has WAN and LAN ports beyond the 1000Mpbs or 1Gb support. NG only has 3 model products that has WAN and LAN ports that support over 1Gb speeds, Orbi 960, 970 series and the Nighthawk RS700.
