JackNapier
Dec 28, 2023Follower
Best Router for Fidium fiber
i have 2gb fiber in the home from fidium. of course their equipment only allows 1gb. To get 2gb speed I was told I need to buy a new router. I called fidium and they recommended a modem that ended...
BH_C
Dec 28, 2023NETGEAR Expert
Based on Fidium's FAQ, the fiber service needs a modem and a router, or a combinded gateway.
NETGEAR routers are only the router part, and you still need modem that is capable of operating 2Gbps speed. Usually the cable modem or gateway equipment is provided by the service provider and you cannot buy it from the retail marekt.
https://www.fidiumfiber.com/faqs
Sometimes, a single device called a gateway can function as both a modem and a router. (You might also hear the term modem router – it’s the same thing.) It’s a one-stop shop for Internet connectivity. That’s what Fidium provides with our WiFi 6 gateway.
