nayeemlinkin
Mar 27, 2018Aspirant
Best Router with Best Design at 60$ range (5000 BDT)
suggest me the best router with design and features, range not matter and dual-band is optional. thanks
michaelkenward
Mar 28, 2018Guru - Experienced User
Best for what?
Start here:
Wireless Routers for Home | NETGEAR
I doubt if there is much there for $60.
- nayeemlinkinMar 28, 2018Aspirant
can you tell me the basic difference between AC routers and N routers ?? i dont know actually which is better... and what AC/N stands for..
- michaelkenwardMar 28, 2018Guru - Experienced User
