bemo47
Nov 18, 2017Tutor
Best solution for old house with large stone walls
Hello, My house is very old with wide stone walls, 70 cms, the wifi is not able to cross the walls, and each room is totally isolated from any wifi network. I have a standard box from Orange, frenc...
- Nov 18, 2017Many homes have coax installed for cable TV. This is common in the U.S.. Since you are France, and living in a stone house, this may not apply to you.
bemo47
Nov 18, 2017Tutor
Thanks for this advice.
When u say Powerline, u mean ethernet over electrical plugs ? what we call CPL in France ?
TheEther
Nov 18, 2017Guru
Yes.
- bemo47Nov 18, 2017Tutor
Ok, thks, got it
But when u say coax could be more practical than ethernet, i don't see why coax could be more easy to install than ethernet ? Its still cable to install across rooms or area to connect ? what is the easy side of coax compared to ethernet ?
- TheEtherNov 18, 2017GuruMany homes have coax installed for cable TV. This is common in the U.S.. Since you are France, and living in a stone house, this may not apply to you.
Ok, i checked Moca and i see that its can be easier if the house is already cabled with coax for home tv, but here there is no other cable than electricity, so anyway i will need to install cables, so better to install directly ethernet i guess.
So, my first step will be to buy a good WiFi router to replace the WiFi from the internet provider's box. I could get some improvement in WiFi only with that.
Then, where i will not get enough WIFi, i will install ethernet cables and WiFi access points where needed.
This could be a plan....
Thanks anyway for help.
Regards
