bemo47
Nov 18, 2017Tutor
Best solution for old house with large stone walls
Hello, My house is very old with wide stone walls, 70 cms, the wifi is not able to cross the walls, and each room is totally isolated from any wifi network. I have a standard box from Orange, frenc...
- Nov 18, 2017Many homes have coax installed for cable TV. This is common in the U.S.. Since you are France, and living in a stone house, this may not apply to you.
bemo47
Nov 18, 2017Tutor
Ok, thks, got it
But when u say coax could be more practical than ethernet, i don't see why coax could be more easy to install than ethernet ? Its still cable to install across rooms or area to connect ? what is the easy side of coax compared to ethernet ?
TheEther
Nov 18, 2017Guru
