Lia1846's avatar
Lia1846
Follower
Jan 29, 2022
Blacklisted and wps disabled but can still connect when pressing wps button on router
Blacklisted and wps disabled but can still connect when pressing wps button on router. I was hoping to fix this, hooefully someone can help me
1 Reply
  • FURRYe38's avatar
    You gave us nothing to go off. NG product model is helpful.
    To get a hold of support. Click on "MyNetgear" at the top.
    Register an account (or login) and then the device.
    From there you can start the support process. Keep in mind that its only free for the first 90 days.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
