JGL991
Aug 14, 2021Guide
Blink Cameras and Broadcast SSID
I want to turn off the broadcasting of the SSID for the 2.4 ghz but, it seems to create a problem for my blink cameras not being able to access the network. Anyone else having this issue?
michaelkenward
Aug 15, 2021Guru - Experienced User
Did you just disable broadcast of the SSID network name? Or was it the wireless radios?
Turning off the wifi for something that needs wifi could cause problems.
- JGL991Aug 18, 2021Guide
Turned off the broadcast of the SSID because I thought that if I turned it off that it would not get hacked
- michaelkenwardAug 18, 2021Guru - Experienced User
There are sniffers that determined crooks can use to find your wifi.
Decent passwords are better protection.
