bkhuelsman
Feb 02, 2021Initiate
Blinking Power Light before and after TFTP Firmware Update
Hello everyone, I attempted a firmware update on my router (AC1750 - R6400 V2) but it failed. In an effort to fix the problem I downloaded a new firmware image from here: https://www.netgear.com/...
- Feb 02, 2021
Sometimes it takes a few attempts. I usually use the windows built in client successfully.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Feb 02, 2021Guru - Experienced User
- bkhuelsmanFeb 02, 2021Initiate
Thank you for the reply. nmrpflash seems to have corrected the issue. I greatly appreciate you help.
- plemansFeb 02, 2021Guru - Experienced User
Glad it worked!
