Jgman4500
Apr 01, 2023Follower
Blinking power light
I am not technology savvy so it may require some simplification of what’s going on but on my app it says my AC1750 router needs an update but my router is currently blinking red at the power light. Fr...
michaelkenward
Apr 02, 2023Guru - Experienced User
Is the router working as it should? Depending on the model, a blinking power light can mean corrupt firmware.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
That page will also have any software, firmware and drivers for your device, if they exist.
Check the section in the manual Troubleshoot With the LEDs.
Follow the advice from microchip8 when it comes to changing the firmware.
