BioHazardBeauty
Mar 12, 2024Follower
Blinking USB light and signal not reaching
Netgear CM400 Modem and AC1000 Router; I just moved into this house and the landlord already had these set up, however, the modem was buried behind a freezer so I dug it out and set it up away from...
michaelkenward
Mar 12, 2024Guru - Experienced User
Which router is that?
AC1000 is not a unique Netgear model number. Many devices come with the AC/AX tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
Look at the label on the device for the Model Number. And, if there is one, include the "V" bit to show the hardware version. If there is no V number, then you have V1.
The only AC1000 I can find is the R6080, pretty well Netgear's cheapest router and launched seven years ago.
According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet, anything faster than 100 Mbps is a waste of your money.
It also slows down whatever is going on in your local network. Newer devices support at least 1000BASE-TX.
Nothing wrong with it being old, just don't expect too much.
