PereNoel
Dec 23, 2022Aspirant
Block Internet but keep access to LAN devices
Hello, I have a NAS on my local network. Router is Nighthawk R7000. I would like to block all Internet access to/from it, but would like to have devices on my LAN still be able to access it. ...
michaelkenward
Dec 23, 2022Guru - Experienced User
You don't say which NSA devices these are, but my experience with several brands is that I have to go out of my way to allow them to get anywhere near the Internet.
Maybe a better place to seek help is on the support site for your NAS.
PereNoel
Thanks - the issue I'm having, though, is not with the NAS itself, but rather with the router. If I enable all connectivity on the router, I can get the NAS to work fine, just the way I want it to. What I'm trying to do, though, is to block Internet access to/from the NAS, while also letting it continue to communicate with my devices on the LAN. From what I've tried so far, it's been all or nothing - either it has access to Internet and LAN, or nothing at all. I just want to disable Internet only.
