Jeffrey_tl's avatar
Oct 31, 2024
Block IP Addresses Being Used
I understand and know how to manually assign IP addresses to devices.  However, is there a way to block IP address being assigned for new devices?  Just for an example I want to put all my security devices etc. 192.168.1.10-20 but currently only have 6 so that would leave 16-20 open for other devices to auto assign to. When I get another security device I would want to manually assigned to 17 but that would mean the device using that address would have to be reassigned?
Is there a way to have devices (cell phones, tablets) to connect to higher IP addresses instead of assigning the lowest available IP address?
I hope my question is clear in what I am asking.
Thank you for your assistance.
    • Jeffrey_tl's avatar
      Jeffrey_tl
      Tutor
      Thank you for the reply however that solution doesn't work since I wouldn't know what the MAC address would be since I haven't purchased it yet.
      I would want to block a certain IP address from being used so that I could assign that certain IP address to new device in the future.
      • FURRYe38's avatar
        Can't be done. You'll need to get the device in and then connected, then setup the IP address reservation at the time the new device is connected.
        Good Luck.
