thesuffering
Jan 11, 2018Tutor
Block Services not allowing more than 1 IP
Trying to use the block services feature to block my kids devices at night so they cannot sit up on the internet all night. I can add one local IP to the block services table, but any others I try a...
- Jan 18, 2018
Hi thesuffering,
What you can try is use a combination of features: Address reservation, Schedule, and Block Services.
First, you can do Address Reservation for your kids devices and set them on a range (i.e. 192.168.1.2-192.168.1.10). Steps are linked below.
http://kb.netgear.com/app/answers/detail/a_id/24091
Second, set a schedule (i.e. 22:00 to 06:00). Steps are linked below.
http://kb.netgear.com/app/answers/detail/a_id/24055
Third, set to block all services. Steps are linked below.
http://kb.netgear.com/app/answers/detail/a_id/24054
Dexter
Community Team
thesuffering
Jan 16, 2018Tutor
So no reply Netgear?
DexterJB
Jan 17, 2018NETGEAR Moderator
Hi thesuffering,
The router feature that we recommend that you look into instead is Access Control. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/23289
Dexter
Community Team
- thesufferingJan 17, 2018Tutor
I have a R6300v2. That option is not showing as available. I have the following options under security:
Block Sites
Block Services
Schedule
Email
Also, I am not looking to block devices at all times (which is what it seems access control does). I want to block those devices only on a schedule (from say 10pm-6am)
- DexterJBJan 18, 2018NETGEAR Moderator
Hi thesuffering,
Dexter
Community Team
- thesufferingJan 18, 2018Tutor
The problem is step 3, block services. I can enter the first IP of the first device just fine. When I try to add a 2nd IP, nothing happens. I click add and it goes back to the block services table with the first IP I entered only. It wont let me add more than 1 IP to the block services table.
I didnt notice the part about setting them in a range. Did that, and the router allowed me to set the range. Itd make more sense to just let me pick whatever IPs I want, but address reservation and the range worked well enough.
