JayMan01
Dec 26, 2021Aspirant
Block Sites List Truncating
So i just noticed this today when I was trying (and failing) to add addtional IPs/URLs to block. For some reason it has stopped letting me add anymore. I also notice that when I try that just th...
KevinLiT
Jan 06, 2022NETGEAR Moderator
Hello JayMan01,
I understand that you are having issues adding additional IPs/URLs to block using the NETGEAR interface. Please provide the device's model number so I can further assist you.
I look forward to hearing from you!
Best,
Kevin
- JayMan01Jan 06, 2022Aspirant
Hello,
Thank you for the reply.
Its is the WNDR3700v4.
Thanks in advance.
- michaelkenwardJan 22, 2022Guru - Experienced User
JayMan01 wrote:
Hello,
Thanks in advance.
That router is from 2015, seven years ago, with its origins in 2009.
Don't expect much.
- KevinLiTJan 21, 2022NETGEAR Moderator
Hello JayMan01,
We have been working diligently to figure out a solution to your issue.
Please provide the following:
Firmware:
Screenshot with truncation issue:
Best,
Kevin
