wawalker1
May 13, 2017Aspirant
Bridge from Comcast Arris TG862G/CT to AC1750 smart router
Need to bridge a Arris tg862g/ct to a Netgear ac1750 Need to configure Arris tg862g/ct bridge mode with Netgear ac1750 r6400 router. This has voip phone also. on the Xfinity comcast isp I...
- May 17, 2017
Hi wawalker1,
1. You can check the link below for the setup procedure for cable connection.
http://kb.netgear.com/app/answers/detail/a_id/22697
2. You can also try MAC spoofing. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
wawalker1
When in bridge mode, the Netgear router's internet should be solid white. It is amber
- DexterJBMay 17, 2017NETGEAR Moderator
Hi wawalker1,
Dexter
Community Team
- DexterJBMay 22, 2017NETGEAR Moderator
Hi wawalker1,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- wawalker1May 26, 2017Aspirant
The MAC spoofing and disconnecting/reconnecting the cable worked. Thanks
