ggilmore2082
Oct 26, 2018Aspirant
Bridge Mode
I'm bridging myXfinity modem with my NetGear WNDR3700v3 router. I chose to enable bridge mode on my Xfinity router (Technicolor DPC3941T), not sure what to configure on my WNDR3700v3 (using dd-wrt) f...
- Oct 26, 2018
> [...] I chose to enable bridge mode on my Xfinity router (Technicolor
> DPC3941T), [...]
Why?
> [...] not sure what to configure on my WNDR3700v3 (using dd-wrt) for
> the bridge mode to work correctly . The WNDR3700V3 is in AP mode right
> now, I cannot get internet access.
If the DPC3941T is in bridge mode, and the WNDR3700v3 in in AP mode,
then you would appear to have no router. You might do better with one
of these devices acting as a router.
> [...] enable routing with the WNDR3700v3, [...]
So, not "AP mode", then. I'd do a settings reset on the WNDR3700v3,
which I assume would restore it to full-function router mode, but, if
it's running DD-WRT, then you may need to consult the DD-WRTdocumentation on that question.
> [...] see if that helps with my internet speeds.
The non-psychics in your audience may know little about your "myinternet speeds", or what causes them to be whatever they might be
(however you might have measured them).
antinode
Oct 26, 2018Guru
> DPC3941T), [...]
Why?
