BrendenWard
May 22, 2021Aspirant
BT hub 6 connection to neatgear ac1200
Hi, at the minute my netgear ac1200 dsl router is plugged straight into the bt broadband. I'm renewing my contract and I need to use the bt hub but when I connect the bt hub to the netgear one via wan...
BrendenWard
If I move the dsl connect to bt hub and just use that the alarm will have to be reset meaning engineer has to come in. I need to use bt hub and somehow get the netgear router to just act as a router not a modem.
antinode
May 23, 2021Guru
> have to be reset meaning engineer has to come in. [...]
Says who? Why?
> [...] I need to use bt hub [...]
Some of us still know approximately nothing about your (unspecified)
"bt hub". Or your (unspecified) "my netgear ac1200 dsl router". Or
your (unspecified) "Alarm".
> [...] and somehow get the netgear router to just act as a router not a
> modem.
Connecting your (unspecified) "the netgear router" to some other
router is likely to cause more changes to the environment of your
(unspecified) "the alarm" than simply connecting it to a different
router.
You don't seem to know enough about either network configuration or
your (unspecified) "the alarm" to know what's possible or required,
making your assertions about what you should do, or what "has to"
happen, unreliable, at best. And you seem unable or unwilling to
provide the most basic information about your equipment, all of which
makes progress seem unlikely.
