google1901
Jul 04, 2023Aspirant
BT (UK) landlines migration to Digital Voice supporedt by Netgear?
I'm just hearing our UK landline will transition to Digital Voice sometime (this year). Support for current phone handset is a direct connection on back of BT router (smarthub2). But they offer a Dig...
CrimpOn
Jul 04, 2023Guru - Experienced User
Unless someone with an Orbi connected to a BT smarthub2 happens to notice this post, his situation sort of screams out "Talk to BT" or search for a BT user forum.
On the one hand, Voice over IP from countless suppliers has been supported on consumer routers for years. Connect the VOIP box to the router, enter the setup information, and "talk". IF BT is giving up on their traditional voice support and switching to a VOIP solution that they have purchased and relabeled from somebody, it should simply connect to the Orbi router.
On the other hand, ISP support for voice is tied directly to their underlying technology. For example, as a Spectrum cable customer, everything Spectrum provides (television, voice, internet) uses specific frequencies on their cable system. At the cable modem (or router), the frequencies used for voice are split off and used to feed the telephone jack on the modem, just as frequencies used for internet are combined into an Internet connection. (See Data over Cable Interface Service Specification: https://en.wikipedia.org/wiki/DOCSIS#:~:text=Data%20Over%20Cable%20Service%20Interface,cable%20television%20(CATV)%20system.
BTs smarthub2 appears to support several technologies:
Fiber to the Curb. Fiber to the Premises. g.fast https://en.wikipedia.org/wiki/G.fast - WOW.
google1901
Love it! Have spoken to BT (Tech support) & the BT community buffs/experts (last 48hrs). The BT (latest) router apparently has DECT support (+ phone socket) so I can plug in our phone base station. Cool! But I bought NETGEAR for a reason & will not go back to a frigging BT hub. BT Tech support say yes I can use (along with their DECT adapter) non BT routers. However, the 'community' buffs say BT hub and that's it; And don't believe BT Tech support, they know diddly squat! As you can see brilliant feedback!
Whether I've to upgrade/replace our Netgear router is OK so long as I don't (daisy chain) rely on a BT hub/router.
