google1901
Jul 04, 2023Aspirant
BT (UK) landlines migration to Digital Voice supporedt by Netgear?
I'm just hearing our UK landline will transition to Digital Voice sometime (this year). Support for current phone handset is a direct connection on back of BT router (smarthub2). But they offer a Dig...
pcbuilder
Jan 31, 2024Aspirant
Hi, All you need to do is Set your netgear to AP mode in the settings. And then switch off the Wifi on the BT SH2 in the settings. Once done connect Lan to Lan or SH2 Lan to internet on your Netgear router. Mine works great.
- michaelkenwardJan 31, 2024Guru - Experienced User
And lose a pile of features that might be the reason for buying a Netgear router in the first place.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
- pcbuilderJan 31, 2024Aspirant
Hi, Yes but it's the only way to get your digital landline to work that I have found.
One alternative is to learn to live with "double NAT".
Your BT gives itself the local IP address:
http://192.168.1.254/
When you set up your Netgear router it wants so use http://192.168.1.1 but it may well see that and opt to use the address http://10.0.0.1
You then have two routers.
I currently have that arrangement. (I am in the middle of BT broadband hell.) I do not recommend it, because the rest of the network gets confused.
You can plug everything onto the network from the Netgear device and just leave the BT box sitting there as a modem and a phone connection for Digital Voice.
I have yet to see if the BT hub will let me put it on http://10.0.0.1 and what the consequences might be.
It is a pity that BT is allowed to get away with forcing customers to use it hopeless hardware and does not provide decent instructions on how to use alternative kit.
I found my setup on the BT Community, where there are other alternatives, but they are not the official "party line".
