FredReed
Feb 23, 2017Aspirant
Build a LAN with a WNDR3400v2
I'm trying to make a wifi LAN with 4 devices for sharing. I don't need full time internet as it's a metered connection and I want to keep data usage down to a minimum. (It seems I need the internet c...
- Mar 02, 2017
FredReed wrote:
I forgot to mention this, I read about and watched a demonstration on "Pixiedust".
I'm not sure if it was a "brute force" attack over the internet or over the wifi signal.
Do you know? I'm sure there are newer ones since then too.
These attacks are to break into wifi. Your router is not vulnerable to Pixie Dust. I haven't seen anything specific on WPS brute force attacks. But if you simply disable WPS on your router, you won't be vulnerable to this whole class of attacks.
Passphrases (and pins) can always be attacked by brute-force (which amounts to trying all possible passphrases). There are ways to slow these attacks down - for instance, if the router is slow to respond after a couple of failed connection attempts, then the brute-force attack will take a lot longer. Even a small delay is enough to make these attacks useless (because there are so many passphrases to try).
If you are worried about this particular threat, you can reduce the risk by turning your router's wifi off when you aren't using it, and by changing the passphrase from time to time. In general, longer passphrases will be harder to discover by brute force guessing.
ElaineM
Feb 24, 2017NETGEAR Employee Retired
Welcome to the community, FredReed
The WNDR3400v2 cannot be used to bridge the Internet access to the rest of the devices you have.
You will need a physical modem to be connected to its WAN/Internet port.
What you're looking for is a router that has a bridge functionality and has a wireless client association.
Or you may want to enable the Tethering option on your S4.
- FredReedFeb 26, 2017Aspirant
Thanks Elaine,
It's true, the bridge comes through a "modem' not the router and I can "tether" to my desktop through the S4.
The router is my "access point" through which my other devices can "share" with each other (but not the internet) after WPS.
That"s how I currently understand how it works. I'm looking for a LAN only but to be able to tether to my desktop when needed through the S4. Therein is my internet only "when I need it". My desktop is the only devce that has no internet access (no service at my apartment). The three others have wifi and are portable.
Do you see issues with my plans for a LAN using the router as an access point?
