FredReed
Feb 23, 2017Aspirant
Build a LAN with a WNDR3400v2
I'm trying to make a wifi LAN with 4 devices for sharing. I don't need full time internet as it's a metered connection and I want to keep data usage down to a minimum. (It seems I need the internet c...
- Mar 02, 2017
FredReed wrote:
I forgot to mention this, I read about and watched a demonstration on "Pixiedust".
I'm not sure if it was a "brute force" attack over the internet or over the wifi signal.
Do you know? I'm sure there are newer ones since then too.
These attacks are to break into wifi. Your router is not vulnerable to Pixie Dust. I haven't seen anything specific on WPS brute force attacks. But if you simply disable WPS on your router, you won't be vulnerable to this whole class of attacks.
Passphrases (and pins) can always be attacked by brute-force (which amounts to trying all possible passphrases). There are ways to slow these attacks down - for instance, if the router is slow to respond after a couple of failed connection attempts, then the brute-force attack will take a lot longer. Even a small delay is enough to make these attacks useless (because there are so many passphrases to try).
If you are worried about this particular threat, you can reduce the risk by turning your router's wifi off when you aren't using it, and by changing the passphrase from time to time. In general, longer passphrases will be harder to discover by brute force guessing.
FredReed
Feb 26, 2017Aspirant
That sounds like a great idea. The wifi signals here are on the opposite side of my apartment building and, I'm in a basement apartment. (It couldn't be more wifi or OTA tv signal isolated!!!) How is the range of the setup you're describing?
William10a
Feb 26, 2017Master
The walls and floor stop most of the wifi it will have to be a mix of wired and wifi
Have you look into wifi repeaters or lan over power ?
Wifi may have a better chance cheaper then the Orbi system as you can place them where needed.
Lan over power needs to be on the same breaker panel and apartment buildings may have panels on each floor
A lan cable would work if the wifi repaers supported a backhaul network the max run would be 100meters or about 330 feet for lan cable.
