FredReed
Feb 23, 2017Aspirant
Build a LAN with a WNDR3400v2
I'm trying to make a wifi LAN with 4 devices for sharing. I don't need full time internet as it's a metered connection and I want to keep data usage down to a minimum. (It seems I need the internet c...
- Mar 02, 2017
FredReed wrote:
I forgot to mention this, I read about and watched a demonstration on "Pixiedust".
I'm not sure if it was a "brute force" attack over the internet or over the wifi signal.
Do you know? I'm sure there are newer ones since then too.
These attacks are to break into wifi. Your router is not vulnerable to Pixie Dust. I haven't seen anything specific on WPS brute force attacks. But if you simply disable WPS on your router, you won't be vulnerable to this whole class of attacks.
Passphrases (and pins) can always be attacked by brute-force (which amounts to trying all possible passphrases). There are ways to slow these attacks down - for instance, if the router is slow to respond after a couple of failed connection attempts, then the brute-force attack will take a lot longer. Even a small delay is enough to make these attacks useless (because there are so many passphrases to try).
If you are worried about this particular threat, you can reduce the risk by turning your router's wifi off when you aren't using it, and by changing the passphrase from time to time. In general, longer passphrases will be harder to discover by brute force guessing.
FredReed
Feb 27, 2017Aspirant
As it stands now, the devices are connected by wifi with no internet. Setting the sharing on each device is confusing as there are 2 Windows
(W7 starter, W10), and two Androids (KitKat 4.4.2,
Marshmallow 6) to set the sharing settings on.
Confusing because each one has a differant looking layout on screen. I'll worry about Internet later. Sharing settings are the important ones right now.
- William10aFeb 27, 2017Master
You would have public lan connecting to the internet of your phone acting as hotspot device allowing you keep track of your data usage for now, Later on you could make work with a wired lan or wired internet service.
- StephenBFeb 27, 2017Guru - Experienced User
FredReed wrote:
I'll worry about Internet later.I'll start here, just to warn you that you likely won't be able to get internet working with this router and your hot spot.
Confusing because each one has a differant looking layout on screen. I'll worry about Internet later. Sharing settings are the important ones right now.The devices won't get internet, but they should still each be getting a 192.168.1.x local IP address when they connect to the router.
Before you graduate to sharing, you should first confirm that you have basic connectivity.
Starting with the windows systems - make sure the wifi connection is classified as "private' on the W10 system, and "home" on the W7.
Try opening a browser in one of the PCs, and entering http://192.168.1.1 Then log into the router's web page, and look for the attached device list. That should give you all four IP addresses (one for each connected device), and you should be able to ping all four from both PCs.
Run CMD on both the Win7 and Win10 machines to try this ping test for each IP address. You enter
ping xxx.xxx.xxx.xxx
where the xxx.xxx.xxx.xxx is a placeholder for one of IP addresses..
