FredReed
Feb 23, 2017Aspirant
Build a LAN with a WNDR3400v2
I'm trying to make a wifi LAN with 4 devices for sharing. I don't need full time internet as it's a metered connection and I want to keep data usage down to a minimum. (It seems I need the internet connection for updating/setup for the router) All I have for internet connection is wireless hotspot on my S4.
"EVERYONE" claims I need "fulltime" internet or WAN to operate a LAN. I've seen C/NET articles that state LAN networks can be set up WITHOUT internet connection. C/NET is a well respected website with a wealth of good information about computer technology. What I can't find is HOW to set up the LAN I want.
The devices I want to share with are: HP TouchSmart IQ500 series desktop w/W10
Asus Eee PC 1005PEB netbook w/W7 Starter
Polaroid M10 2-1 tablet w/Marshmallow
Galaxy SPH1337 S4 smartphone w/KitKat 4.4.2
It's a conundrum and challenge for me and would love for a knowledgeable tech person to help me figure this out. I'm willing to email off here and will post results to this if it's solved. I admit, it's bigger than the subject line.
OH, how do I change my email address here? Nothing listed in my profile or settings.
FredReed wrote:
I forgot to mention this, I read about and watched a demonstration on "Pixiedust".
I'm not sure if it was a "brute force" attack over the internet or over the wifi signal.
Do you know? I'm sure there are newer ones since then too.
These attacks are to break into wifi. Your router is not vulnerable to Pixie Dust. I haven't seen anything specific on WPS brute force attacks. But if you simply disable WPS on your router, you won't be vulnerable to this whole class of attacks.
Passphrases (and pins) can always be attacked by brute-force (which amounts to trying all possible passphrases). There are ways to slow these attacks down - for instance, if the router is slow to respond after a couple of failed connection attempts, then the brute-force attack will take a lot longer. Even a small delay is enough to make these attacks useless (because there are so many passphrases to try).
If you are worried about this particular threat, you can reduce the risk by turning your router's wifi off when you aren't using it, and by changing the passphrase from time to time. In general, longer passphrases will be harder to discover by brute force guessing.
- FredReedAspirantI currently have a slide show from my W10 showing on my W7 and vice-versa.
Grrrr on the Androids!- StephenBGuru - Experienced User
As we've discussed over PM, there are apps on Android that support SMB (Microsoft Network Sharing). Solid Explorer and ES File Explorer are two that I've used. GoodReader works with iOS, likely there are others.
Of course that just lets you access the file. Rendering it properly also requires the right app(s).
- FredReedAspirantI'm not connected to the Internet so unless they break into my router when it's on, I get no popups or intruders.
Right now, I'm looking to access my 2 Androids from the PCs and my PCs from my Androids. Haven't figured that out yet. PC to PC is working through home groups at the moment. As normal, finding any file sharing settings on the Androids has proven elusive. - FredReedAspirantThanks StephenB,
You're right, the secured systems are much harder to crack. Mine was not secure two years ago but then no one did anything to my computer, fortunately. It was pretty scary though to watch my pointer going through my files and I wasn't touching my mouse! It was as if there was a remote connection set up. There wasn't!!
It was through this same router too. WPS wasn't used though and I'm looking to turn it off if it isn't already. I now live in a differant area.
The security is also set on the 2nd highest setting.
When I'm done, I now turn off the router so there's no connection being broadcast.
I'm at the point of selecting what to share and learning how to "see", "broadcast" and "copy" my files to the other computers and someday to a tv.
The downloading is done through a public wifi on one of my portables.
Most information comes from the safest website on this earth. (I'll let anyone know privately)
I'm not advertising but the "free" AV
installed on my computer has a "trusted" website marker on all the listed sites. It places a colored marker, green with a checkmark, red or black with a question mark. You know which sites have a good, bad or unknown reputation. You can look at it. If there's an issue, you can mark it red. Conversely, if it good, it can be marked trusted. This is another method of keeping the bad stuff out. Netgear wants you to have a safe time on the internet. So do I.
Now, it"s late. Good night.- William10aMaster
The worst part the scene you paint with the mouse pointer moving and files being access by someone who broke into your network is letting them yourself under the story that they work for Microsoft's Internet security. The scam that has been going on for years a foreign sounding voice calls and says your computer has a problem and they are from Microsoft Internet security they have you look for curtain number on your windows it will be there it has been a part every windows put out. The true scam starts when they want remote access to your computer and find errors in the event logs that are normal and offer to fix the problems with their magically software for just 400 dollars even if you refuse they say that you paid 400 dollars for their service and offer to refund but you have to give a credit card number to get it. They claim if you have a Apple computer they can fix it remotely too.
- FredReedAspirant
Thank you William10a,
I never heard a voice when it happened at that time. What did happen was it actually opened my files!
WHILE I WATCHED MY SCREEN!
They were MY files, with MY information on them not some psudo make believe files. I did get that
one you mentioned that actually called me on my phone and offered that $400.00 dollar fixit charge.
I have no credit card, I told him to take a hike! I already paid a reputable company for computer service, not him.
Now, every now and again I get a popup that vocally claims I have a trogan, virus etc and
claims I have to install a "Microsoft" program or call a "special" phone number to "clean" my
computer. It happens only when I'm surfing and hit on a malicious website. Their screen will lock up
my mouse pointer "clicks", all except their "button" and freeze my screen response and I'll need to use
Task Manager to close the browser and reopen with a fresh search address. (I never click "restore browsing session")
It only happens when I tether with my smartphone and I'm online, not when I'm using my LAN which
has NO internet connection at all. I have an Avast subscription to clean and restore operability
and speed to my computer. What I need then is an unmetered connection as it can take hours to
straighten out my computer. My NETGEAR router is working just fine and Avast has serviced my computer
through this same router when I used to have a high speed cable connection.
- FredReedAspirant
I have now gone through the set up of my LAN with the help of StephenB, flexed my new found Aspirant
muscles and had to step back. StephenB, you have been immensely patient with me and deserve the kudos
for your help. I will be working these procedures to memorize them. Now to find the kudos button for
StehenB. Great work!
- FredReedAspirantHmmm,
W10 Cortana won't let me open CMD. Did yesterday.- FredReedAspirant
OK, got W10 command prompt to work. Now I forget why I wanted to use it.
To check the IP address and try pinging the W7 system??? Not sure, as I'm not 100% sure where you are at right now.
The main thing is that you were able to get into the settings pages for the router. That's great. BTW you can also see the attached devices from the router, so that will simplify the CMD and ipconfig stuff. We shouldn't need it much now, if at all.
FredReed wrote:
I blocked "intruder" users but should I change the admin and password as there's no WAN connection?
I'm not completely sure I understand what you blocked.
No one can get into your router from the internet, since there is no internet connection. If someone were to connect to your wifi network (guessing the wifi passphrase), they could access the router itself if they also guess the admin password. The risk in your case is pretty low, there's not that much they could do from the router. The bigger risk is that they'd get into one of your windows PCs.
So getting the WiFi security right is more important than the admin password in your case. The default WPA2-PSK (AES) security is what you want. The built-in network passphrase should be pretty good, I suggest you use it (or something similarly structured). The network name is up to you, but you probably shouldn't use a network name that lets people identify you. Again, the default on the label is fine.
That said, you shouldn't use the default password. But you don't need to go too crazy over picking something. 8-10 characters, with a capital letter, a number, and punctuation symbol should be strong enough. You could write it down and tape it to the router if you have trouble remembering it. If a bad guy's in your apartment, the router password is the least of your worries.
- FredReedAspirantInteresting confusing W10 network error box.
It says there is another computer with the same IP address. Contact system admin. Details in Windows system event log. Looking there now... If I can find it. - FredReedAspirantI do wonder, I blocked "intruder" users but should I change the admin and password as there's no WAN connection?
- FredReedAspirantI just wrote a comprehensive post to send here after logging into the router. I turned on wifi on my S4 to find the numbers the router assigned and forgot to shut off wifi. Lost the entire post.
AH... I'll learn, wifi and tether DON'T work together.
Would be cool if they did.
I did learn a lot going through the settings pages on the router. I probably will have questions later as I use this setup. - FredReedAspirantI also see "Link-Local IPv6 Addresses on W7 and W10. Much longer numbers!
As this is a dual band, how do I know which band works better, 2.4 or 5.0?
Now I'm looking up the Android "command prompt" method.- StephenBGuru - Experienced User
As this is a dual band, how do I know which band works better, 2.4 or 5.0?IPv6 is a different numbering scheme. There are only 4 billion IPv4 addresses - which seemed like a lot in the 1980s, but they ran out this century. There are a variety of stop-gap measures in place to keep Ipv4 running, but IPv6 is intended to be the long range solution. The very long numbers are to accomodate a lot more devices (about 3.4×1038 ).
So those addresses are not about dual band.
But your router does support dual-band. You should see two different WiFi network names for it - the 5G one likely has -5G at the end of its name. It's possible that your PCs won't see this network (they might only use 2.4 ghz). But your S4 should be seeing it. 5G will give you better performance. The signal doesn't travel as far, so there will be less competition from your neighbors.
You'll still only have one private network btw - you just have three different ways to connect to it (ethernet, 2.4 ghz, 5 ghz). All will use the same ipv4 address range.
1) Yes, I was on the S4 tether at the time so, that is the S4 ipconfig, yes?
Yes.
4) Both Android "S4 and M10" don't have CMD.EXE ipconfig functions as they are Android OS?Yes. There are ways to see the addresses there too, but they are different and I thought the PCs would be enough. If you go into the settings of the phone, you can access the wifi settings (on nougat that's under "connections", I don't recall the marshmallow or kitkat organization). You can tap on the network name, and it will show you the IP address (and the encryption method and some indication of signal strength).
There are also some Android apps that let you run ping.
BTW, I just call the black window the "CMD Box".
2) Did the ipconfig from W7 once, all were "Media disconnected"
Twice with router connected and I'VE was 10.0.0.4
All the rest were "Media disconnected"
3) Did ipconfig on W10, found I'VE to be 10.0.0.2
All others were "Media disconnected"
(Interesting item: W10 computer has two more wireless LAN adapter local area connections)This is great (and a bit unexpected). Netgear routers use 192.168.1.x addresses out-of-the-box. Yours is using 10.0.0.x (just like mine is).
So if you are untethered on the PCs, you should be able to run CMD and enter ping 10.0.0.2 on the W7 PC, and you should get responses from the W10 PC. You should also be able to ping 10.0.0.4 on the W10 PC and get responses from the W7
And the way to reach your router is to enter http://10.0.0.1 in your browser's address bar. Again, you need to be untethered for this to work.
If you don't know the router's admin password, you might need to do a factory reset on the router. That will reset the router's password to password. It will also switch you back to 192.168.1.x addresses. But let's cross that bridge when we get there.
All the rest were "Media disconnected"That is usual. For instance, you don't have ethernet connected, but you have an ethernet port. You likely also see several adapters that start with "tunnel". those aren't real devices, they are virtual. All that clutter does make ipconfig a bit messy to look through.
(Interesting item: W10 computer has two more wireless LAN adapter local area connections)That is interesting and we should look into it after we get through the basic connectivity and get you into your router setup.
I realize this is slow-going but you are getting very close.
- FredReedAspirantNO wait!... where I referred to the phone outlets and extension phones, instead, each adapter is like an additional phone LINE in each computer (multi-line extension phone). I'm remembering the phones with the 5/6 clear plastic buttons on the front that light up (assign the IPv4 number). Am I getting this?
If there is only one number assigned to that phone, only one button (IPV4 address) will work.
The rest are as I observed earlier, disconnected but available for use later. Right? - FredReedAspirantThe I'VE is supposed to IPv4 in my 10:10pm post!!! Stupid autocorrect!!!
