MYnetGD49's avatar
Jul 16, 2022
Buy New Router N300 WNR2000V5
I presently have a Netgear N300 Wnr2000V2 Router. I am experiencing very slow connections and Spectrum suggested replacing it with a N300 Wnr2000V4 or N300 Wnr2000V5. Are these still available and if...
  • plemans's avatar
    Jul 18, 2022
    I think $49 for a gigabit capable RAX35 would be way under budget 🙂 and a massive upgrade versus the WNR2000 or the R6120.
    Performance on both of those is pretty anemic but the RAX35 has some pretty solid speeds. Only downfall is its a 2x2 antenna device but has 160hz wide channels. Again, still way above the other devices.
