cuse165
Jun 23, 2018Aspirant
Bypassing my DNS
I added a DNS that blocks adds when I am online I see every add there is so I tried another DNS same thing so the I tried opendns and same thing as the other two. My router is like bypassing my setti...
- Jun 23, 2018
Well first I would like to thank you for your rude answers and how you put your answer was uncalled for. If you had nothing to say dont answer my question. Dont take my question and pick it apart and be a smart ass Next time I need a smart ass answer I know who I can contact.
antinode
Jun 23, 2018Guru
> I added a DNS [...]
To what? What is the resulting DNS configuration after you "added"
this (secret?) DNS server to whatever you had before (on whatever you
had it)?
> [...] My router is like bypassing my settings and not using any of my
> DNS.
Are you using some kind of computer/device? What is its DNS
configuration? Is your "My router" "like bypassing my settings", or is
your client device using something other than your "My router" for DNS?
What is your "My router"? (Model, hardware version, firmware
version, ...?)
> [...] There is a page that tells you if you are connected to there DNS
> servers.
Which page, on what?
> [...] Anyone know anything [...]
From that problem description, I don't know much. As usual, showing
actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations. An accurate, detailed report of actual events would be
much more interesting than your analysis/interpretation of the problem
("My router is like bypassing my settings", ...).
- cuse165Jun 23, 2018Aspirant
- michaelkenwardJun 24, 2018Guru - Experienced User
Apologies for that. Most of the regulars here try to be helpful without being rude or to belittle people.Did you fix your problem?
My approach to "ad spam" is to use a browser add-in that blocks ads.
Messing around with DNS servers is a bit too complicated and open to error for my liking. I don't recall anyone else using that approach, so I doubt if you will find much around here on that topic.
- cuse165Jun 24, 2018AspirantWell thank you I do apologize for what I said. I was just looking for info
