bjskiers
Nov 03, 2020Follower
C-3700
Where can I find a PIN# on this router?
Nov 03, 2020Guru - Experienced User
antinode
Nov 03, 2020Guru
> C-3700
C3700[v1] or C3700v2? Look for "Model" on the product label.
To do what, exactly? If you mean the router's WPS PIN, then visit
http://netgear.com/support , put in your (actual) model number, and look
for Documentation. Get the User Manual. Read. Look for "WPS". Keep
looking until you find "Specify WPS Settings".
Regarding "PIN#", see: http://antinode.info/complaints/aer.html
> https://kb.netgear.com/31575
That KB article deals with the client-device WPS PIN, not the
router WPS PIN.
Terse questions can waste more time than they save.
