netspert
Dec 01, 2019Aspirant
C3000 as a Range extender?
Could a C3000 be used as a Range Extender by connecting it to a primary wifi router with a long Ethernet cable? Any configuration tricks?
- Dec 01, 2019
> primary wifi router with a long Ethernet cable? [...]If by "Range Extender" you mean "wireless access point", then I'd
expect so.It's possible to configure almost any router as a wireless access
point. See, for example:https://community.netgear.com/t5/x/x/m-p/1463500
That's written for a C6300-as-WAP, but the steps are about the same for
any other router (any make/model) which lacks a one-step WAP option.
antinode
Dec 01, 2019Guru
expect so.
- netspertDec 01, 2019Aspirant
That makes sense - thanks.
