netspert's avatar
netspert
C3000 as a Range extender?
Could a C3000 be used as a Range Extender by connecting it to a primary wifi router with a long Ethernet cable?  Any configuration tricks?
  • antinode's avatar
    Dec 01, 2019
    > primary wifi router with a long Ethernet cable? [...]
       If by "Range Extender" you mean "wireless access point", then I'd
    expect so.
       It's possible to configure almost any router as a wireless access
    point.  See, for example:
          https://community.netgear.com/t5/x/x/m-p/1463500
    That's written for a C6300-as-WAP, but the steps are about the same for
    any other router (any make/model) which lacks a one-step WAP option.
