jmartin6
Mar 13, 2020Tutor
C3700 No visibility for IP & DNS Settings
Why can’t I see or have access with visibility for IP & DNS settings when using Netgear Genie.
- Mar 13, 2020
what address are you entering?
Try hardwired into it.
If you've changed the password/have the incorrect password and don't have password recovery setup, then you'll need to factory reset to get back into it.
Mar 13, 2020Guru - Experienced User
Because its not built into the app and needs to be adjusted from the browser?
- jmartin6Mar 13, 2020Tutor
I enter the router address into the browser but does not open up or if it does open up to login page it does not recognize the admin password even though I know it is correct.
- plemansMar 13, 2020Guru - Experienced User
- jmartin6Mar 13, 2020TutorWill try the hardwire approach and get back to you.
Thx for your support!!
