jmartin6's avatar
Mar 13, 2020
C3700 No visibility for IP & DNS Settings
Why can’t I see or have access with visibility for IP & DNS settings when using Netgear Genie.
  • plemans's avatar
    Mar 13, 2020
    what address are you entering?
    Try hardwired into it.
    If you've changed the password/have the incorrect password and don't have password recovery setup, then you'll need to factory reset to get back into it.
