Foster14
Sep 05, 2021Follower
C3700 Router WiFi connection
Connectivity was slow, so we unplugged the router and re plugged it back in. No internet since. We have done a hard reset with a pin and still the same problem.
1 Reply
Foster14 wrote:
Connectivity was slow, so we unplugged the router and re plugged it back in. No internet since. We have done a hard reset with a pin and still the same problem.What do the LEDs on the C3700 look like?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Use LEDs to Troubleshoot.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
