hallux
Oct 18, 2020Aspirant
C3700v2 Firmware Downgrade
Been having connection issues with my C3700v2 since getting it, connection drops, speeds dropped as low as 0.03mb/s... I'm thinking it may be due to a firmware mismatch, my firmware displayed via the...
michaelkenward
Oct 19, 2020Guru - Experienced User
Firmware for cable modems is beyond Netgear's control.
If your firmware is outdated, you cannot manually upgrade your cable modem’s or modem router’s firmware. You must contact your Internet service provider (ISP) to upgrade your firmware.
- halluxOct 19, 2020AspirantIf upgrading was the case... then yes, the ISP could help however I need to DOWNGRADE... as my post stated.
- michaelkenwardOct 19, 2020Guru - Experienced User
hallux wrote:
If upgrading was the case... then yes, the ISP could help however I need to DOWNGRADE... as my post stated.My answer has nothing to do with upgrading.
If you read it closely you will see that it tells you who has to change the firmware.
Up or down, it is the ISP.
Okay and when the ISP refuses? The end user who spent money on a product they cannot use is **bleep** out of luck because the manufacture refuses to provide various firmwares available for individuals use.
