oriza
Jul 21, 2021Aspirant
C6250 not detecting ethernet cable
I tried for the first time to use an ethernet cord with my C6250 yesterday. I plugged one end of the ethernet cord into the ethernet port on the router, and the other end into the ethernet port on my...
michaelkenward
Jul 22, 2021Guru - Experienced User
oriza wrote:
I tried for the first time to use an ethernet cord with my C6250 yesterday. I plugged one end of the ethernet cord into the ethernet port on the router, and the other end into the ethernet port on my laptop.
By "the router", do you mean the C6250? That is a modem router.
I ask partly because you have posted in the section of this community given over to General WiFi Routers (Non-Nighthawk & Non-Orbi). Questions about the C6250 are best posted here:
Is your C6250 connected to the Internet? What do the LEDs on the front look like?
Then there is this bit:
oriza wrote:
....my Network Connections window says "network cable unplugged" under "Ethernet".
What is this "Network Connections window"? Something in Windows on the laptop? A browser?
- orizaJul 22, 2021Aspirant
Thanks for the response!
1. "By "the router", do you mean the C6250? That is a modem router."
Hmm, okay, I assumed it was a WiFi router because in the C6250 user manual it calls it a "WiFi Router". I can post this in the other forum you linked and delete this later.
2. "Is your C6250 connected to the Internet? What do the LEDs on the front look like?"
It is connected to the Internet. I'm typing this post using the WiFi right now :) All of my LEDs are solid green *except* the ethernet LED, though the 2.4 GHz and 5 GHz LEDs are blinking (which is normal since they're transmitting data). The Ethernet LED is off regardless of whether or not it is connected to anything else via an ethernet cable.
3. "What is this "Network Connections window"? Something in Windows on the laptop? A browser?"
Sorry for the lack of clarity. It's a Windows setting in Control Panel. I'm looking at the "Ethernet" option. See attached image, or here on Imgur.
I realized I never mentioned my OS-- I run Windows 10.
Edit-- my im
- antinodeJul 22, 2021Guru
> I did look into the troubleshooting options in the manual.
And the LED descriptions? Including the LEDs at the LAN Ethernet
ports?> [...] So I don't know what else to try.
Really? You might try the tests which I suggested before. Look for
"You might try", avove.
> [...] I can post this in the other forum you linked and delete this
> later.Not worth the bother. None of that makes any significant difference.
"Network cable unplugged" doesn't mean much without knowing to what
the Ethernet port is connected (if anything)."connecting your (unspecified) laptop to your (unspecified) desktop"
might change that, which, like a better LED description, _would_ be
interesting information.- orizaJul 23, 2021Aspirant
" And the LED descriptions? Including the LEDs at the LAN Ethernet ports?"
Yes? Like I said earlier, all of my LEDs are solid green *except* the ethernet LED. The Ethernet LED is off regardless of whether or not it is connected to anything else via an ethernet cable. This means according to the description in the manual, that "if the Ethernet LED is off, then no device is connected to an ethernet port." Is there something else I should be looking for?
" "connecting your (unspecified) laptop to your (unspecified) desktop" might change that, which, like a better LED description, _would_ be interesting information."
Okay, I gave a description earlier in this thread of my router's LEDs. "All of my LEDs are solid green *except* the ethernet LED, though the 2.4 GHz and 5 GHz LEDs are blinking (which is normal since they're transmitting data). The Ethernet LED is off regardless of whether or not it is connected to anything else via an ethernet cable." Is there some other kind of LED description that would be helpful?
I connected my laptop (Lenovo Thinkpad T450 running Windows 10, sorry for not being specific about the model before) to my desktop (which I built so I'm not sure what model to give-- the motherboard is a gigabyte h110m-s2h if that helps?) I am not really sure what to look for, so let me know if there's something I should post about, but I noticed that the "Ethernet" window in the Network Connections window in Control Panel now says "Unidentified network" instead of "Network Cable Unplugged". See image here.
Finally, you are correct that my ethernet is not in Bridge mode.
I appreciate all the responses y'all have given me. I am also not quite sure where the impatience/curtness/sarcasm is coming from in some of these replies. I'm new and am really trying not to be stupid or an idiot, but at the same time I don't necessarily know what is obvious and what isn't because I'm new. I'm getting a lot of great info from you all, and so sometimes I miss specific steps or things that you tell me because I'm trying to parse it all. I'm sorry I missed the "you might try" section, and I'm sorry if my posts came across as rude or obnoxious or whiny in any way. I did not intend them that way at all-- it's hard to communicate tone of voice via text, I genuinely meant to sound polite and respectful. I hope this comment also sounds polite/respectful as well.
- michaelkenwardJul 23, 2021Guru - Experienced User
The copy I found calls it a WiFi Cable Modem Router on the top of just about every page in the manual. I asked to eliminate any possible confusion.
Two possibilities occur to me: the LAN ports on the C6250 are bust; there is something amiss with the things you are connecting. Can you plug the laptop into a different Ethernet device to confirm that this is not where the problem lies?
I assume that the C6250 is not in "Bridge" mode. You would only need to do that if you were using the C6250 as a modem only and using another device as a router.
- antinodeJul 23, 2021Guru
> [...] I asked to eliminate any possible confusion.
Not to _create_ it? This is a LAN problem. What possible difference
would the presence/absence of a modem make?> [...] Can you plug the laptop into a different Ethernet device to
> confirm that this is not where the problem lies?I'm such a dope. Why didn't _I_ suggest anything like that? Oh,
wait...> I assume that the C6250 is not in "Bridge" mode. [...]
Even if it were, do you think that that would affect the Ethernet
LED or the port-status LEDs? I doubt it.
