rshanehope
Oct 06, 2019Initiate
C6250 Router Keeps Dropping Internet
Hi There, My router all of sudden started dropping our internet connection. I can unplug from wall and cable and reconnect it and it'll work for about a day and then the next day it stops working a...
- Oct 07, 2019
This is actually the forum you want:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
I'd include a screen snip of your connections page of your modem. This can help people to help you. Another thing to try is check to make sure you connectors are tight, not corroded, coax line isn't kinked, remove any splitters (if possible) or amplifiers. These can all cause problems with your signal and cause issues. Worth removing/fixing to try to troubleshoot.
rshanehope
Oct 14, 2019Initiate
Thanks my friend, the splitters was the issue. Once I removed them i’m back in business.
Oct 15, 2019Guru - Experienced User
glad to hear it was a simple fix!
