darren-stoll's avatar
darren-stoll
Follower
Jun 02, 2021
C6250 Slow Upload Speeds
I'm directly connected to the modem on Windows 10, so no wifi testing being done here.
I'm currently paying Comcast for 100 down/5 up. Today, I've been having severe issues getting my upload above 1 Mbps when trying to stream content through Twitch TV. When I run speedtests on speedtest.net, I get about 4-5 upload going through Comcast's server. However, when I run it through Google Speedtest, I barely get 0.5 upload.
I contacted Comcast today to see if they were finding any issues on their end. They ran some diagnostics and find no issues on their end when they tried connecting to the modem. They suggested I contact Netgear for support on the issue.
I double-checked the modem settings based on previous posts, and everything looks fine as far as I can tell. However, I'm still having problems after several reboots and reconnections. Please advise. Thank you in advance.
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel459000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnabledBPI+
IP Provisioning ModeHonor MDDhonorMdd(4)
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM2564459000000 Hz0.5 dBmV39.5 dB00
2LockedQAM2565465000000 Hz1 dBmV39.5 dB00
3LockedQAM2566471000000 Hz1.3 dBmV39.7 dB00
4LockedQAM2567477000000 Hz0.6 dBmV39.6 dB00
5LockedQAM2568483000000 Hz0.8 dBmV39.6 dB00
6LockedQAM2569489000000 Hz0.9 dBmV39.5 dB00
7LockedQAM25610495000000 Hz1.1 dBmV39.7 dB00
8LockedQAM25611501000000 Hz-0.1 dBmV39.4 dB00
9LockedQAM25612507000000 Hz0.3 dBmV38.6 dB00
10LockedQAM25613513000000 Hz0.4 dBmV39.4 dB00
11LockedQAM25614519000000 Hz0.4 dBmV39.4 dB00
12LockedQAM25615525000000 Hz-0.5 dBmV39.2 dB00
13LockedQAM25616531000000 Hz-0.8 dBmV39 dB00
14LockedQAM25617537000000 Hz0.1 dBmV39.1 dB00
15LockedQAM25618543000000 Hz-0.5 dBmV38.9 dB00
16LockedQAM25619555000000 Hz-1.1 dBmV38.7 dB00
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA135120 Ksym/sec17300000 Hz45.3 dBmV
2LockedATDMA165120 Ksym/sec36500000 Hz47.8 dBmV
3LockedATDMA155120 Ksym/sec30100000 Hz47.3 dBmV
4LockedATDMA145120 Ksym/sec23700000 Hz46 dBmV
No RepliesBe the first to reply
