kidnicaris
Jul 12, 2021Aspirant
C6250 Wifi is very slow
The Wifi connection is terribly slow with with both 2.4Gh and 5Gh. When connected with a 3ft cat5e my laptop gets 100Mbps down but on WIFI I only get 25Mbps. That is wihtout moving it, so still with...
kidnicaris
I guess the pic of my wifi settings didn't upload, another fail for Netgear. Okay, I am on channel 11 and yes I have tried other channels. I've tested it with my laptop, desktop, and cell phone each with the other devices disconnected and all get 25mbps when they are the only device. The desk is the only device with a 5gh antenna. What do you mean by that's just the speed in your area? My laptop is 3 ft away from the router and if I use an ether net cable i get 100Mbps. My question is why is the wifi slow?
Jul 12, 2021Guru - Experienced User
2.4ghz is slow.
And it suffers from interference.
Its the whole reason for 5ghz/6ghz is the higher bandwidth they allow for more speed.
But they don't broadcast as far or through as much materials.
My old R6300 usually only hit 30-40mbps over 2.4ghz. but 5-8x faster over 5ghz.
